Modbus integration - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Modbus integration (/showthread.php?tid=3761) |
Modbus integration - Alexander - 20.12.2021 Hi, I have manage to read temperature values in LM, but I am struggling with these on my uploade image. Not sure how to write these in my .json file. I added my profile. RE: Modbus integration - Daniel - 21.12.2021 Did you try adding "writable": 1 to your profile? RE: Modbus integration - admin - 21.12.2021 Also check the maximum temperature register address. It should be 38 not 36. RE: Modbus integration - Alexander - 21.12.2021 (21.12.2021, 09:41)admin Wrote: Also check the maximum temperature register address. It should be 38 not 36. Where do I check that? But how can I add this in my profile: RE: Modbus integration - admin - 22.12.2021 Maximum temperature: For Hot water demand add this to the mapping array: Code: {
"name": "Hot water demand",
"bus_datatype": "uint8",
"datatype": "uint16",
"type": "register",
"address": 56,
"writable": true
}RE: Modbus integration - Alexander - 25.12.2021 (22.12.2021, 07:50)admin Wrote: Maximum temperature: Hi, thank you for that. How does I map this function. I've tried this: { "bus_address": "12/0/7", "name": "Kjøremodus", "bus_datatype": "7", "datatype": "u8", "type": "register", "address": 237 }, Butr this gives me value 1 all the time. Should get 0 for Auto, 1 for Manual and 2 for Ad.heat. RE: Modbus integration - Erwin van der Zwart - 25.12.2021 Try with "dataype":"uint16" as "u8" is not a valid datatype. See https://openrb.com/docs/modbus.htm |
