zero tier connection problem - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: zero tier connection problem (/showthread.php?tid=3772) |
zero tier connection problem - balatis - 23.12.2021 Hello everyone, i have problem with a lot of logic machine of my projects with the communication between the lm5 and zerotier. In zerotier i see that the device is online but when i put the adress to sign in the lm5, the device does not responding. Also on lm5 i see that the connection is ok for the zerotier. What do you think about this malfunction?? RE: zero tier connection problem - Daniel - 23.12.2021 Did it ever worked? Or is this just sometimes happening? RE: zero tier connection problem - balatis - 23.12.2021 (23.12.2021, 15:26)Daniel Wrote: Did it ever worked? Or is this just sometimes happening? This is just sometimes happening RE: zero tier connection problem - admin - 24.12.2021 ZeroTier is a third-party solution that we don't have any control of. Certain routers might prevent ZeroTier from working in certain situations. Sometimes pinging before connecting via browser helps. You can try installing the latest package to see if it helps: https://dl.openrb.com/pkg/zerotier_1.8.4-1_imx6.ipk (System config > System > Packages > (+) Button). RE: zero tier connection problem - CristianAgata - 24.12.2021 (23.12.2021, 15:23)balatis Wrote: Hello everyone, i have problem with a lot of logic machine of my projects with the communication between the lm5 and zerotier. In zerotier i see that the device is online but when i put the adress to sign in the lm5, the device does not responding. Also on lm5 i see that the connection is ok for the zerotier. What do you think about this malfunction?? I had got the same problem, my work around it was that before connect I will change from private to pubblic the connection and before close I turn again in private. BR Cristian |
