CSS opacity control onclick - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: CSS opacity control onclick (/showthread.php?tid=3783) |
CSS opacity control onclick - adiaz - 30.12.2021 Hello, We have buttons that we want to change opacity to 0 onclick and after 3s they go back to opacity 1 (with fade or some animation). We want to do it only with CSS. Without using javascript. Is this posible? Thanks! RE: CSS opacity control onclick - admin - 03.01.2022 It's not possible to do this without JavaScript. Animation will work only until the mouse button is released. So only very short animations can be done this way. JavaScript: Code: $(function() {
$('body').on('click touchstart', '.item-control', function() {
this.classList.remove('active');
this.offsetHeight;
this.classList.add('active');
});CSS: Code: .item-control.active {
animation: clickanim 3s ease-out;
@keyframes clickanim {
0% {
opacity: 1;
10% {
opacity: 0;
100% {
opacity: 1;
}RE: CSS opacity control onclick - adiaz - 03.01.2022 (03.01.2022, 06:20)admin Wrote: It's not possible to do this without JavaScript. Animation will work only until the mouse button is released. So only very short animations can be done this way. Hello admin! Thanks for the reply. It works on my laptop but not working with Smartphone. Tried on my Iphone and with Android. Any suggestion? Thanks! RE: CSS opacity control onclick - admin - 03.01.2022 Replace click with click touchstart so it handles both mouse and touch events. RE: CSS opacity control onclick - adiaz - 03.01.2022 (03.01.2022, 10:51)admin Wrote: Replace click with click touchstart so it handles both mouse and touch events. Okai, now it works on both systems but not as we want. When we click a button it does the animation but if we click another, the animation occurs on this button and the previous button. If we click a third button the animation occurs on the 3 buttons. Suggestion? Thanks admin! RE: CSS opacity control onclick - admin - 03.01.2022 If you want to cancel previous animations then replace Custom JavaScript with this: Code: $(function() {
$('.item-control.active').removeClass('active');
this.offsetHeight;
});RE: CSS opacity control onclick - adiaz - 03.01.2022 (03.01.2022, 11:42)admin Wrote: If you want to cancel previous animations then replace Custom JavaScript with this: Perfect admin! Work like a charm! Thanks. |
