Real estate bms - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Real estate bms (/showthread.php?tid=3785) |
Real estate bms - alias74 - 03.01.2022 Mi intent is to use the logic machine to record consumption from 200 apartments, only active energy consumption. The devices are knx meters. Ali we will have a smaller visually interface for building management 3 or 4 panels, nothing fancy. Can you tell me that the device is power enough to deal with this request. Also I want do be able to download the monthly consumption. Thanks RE: Real estate bms - Daniel - 03.01.2022 Latest hardware should handle this if you keep it with low resolution. I'm assuming that LM will not be doing anything else. I would probably use 2 LMs anyway. |
