garbage can trigger - Printable Version
+--- Thread: garbage can trigger (/showthread.php?tid=3794)
garbage can trigger - pioneersteffen - 05.01.2022
Hi @all,
I want to create a script that gives me a trigger object when a garbage can will be picked up today. Therefore I have all possible pick up dates available in an .ics calendar or I can easiliy convert it to an Excel.
Is there any script / starting point you can help me with?
Many thanks for your help.
Best Regards
Steffen
RE: garbage can trigger - admin - 14.01.2022
ICS is a text format so it can be parsed via a script. Can you provide an example ICS that you want to use? Is it stored somewhere where LM can retrieve it automatically?
RE: garbage can trigger - pioneersteffen - 14.01.2022
Hi Admin
many thanks for your reply.
Attached you can find the example file. I want to check if the actual date is similar to a pick up date in the ics and if yes a group address with the kind of garbage ("Restmüll", "Gelber Sack", etc.) should be send.
The ics I getting from a website as a download and is not stored anywhere.
Many thanks for your help!
Best Regards
Steffen
RE: garbage can trigger - admin - 17.01.2022
Here's an example that you can use a starting point. data variable should contain the ICS file contents that you get externally.
First the script parses ICS events into a table. Then it looks for an event with a matching date. summary variable is the summary field (kind of garbage in your case) of the found event or an empty string. Change 1/1/1 as needed and use 250 byte string as the data type of this object.
url = 'https://p35-caldav.icloud.com/published/2/MTQzMzA1NjcxOTE0MzMwNXFFkpAlN-RmUw02iYPAHdjXli1qufT3m2kVvFAFS2VXJLUhJ6r02NrhV15B8p_WoReJ0k5wrU4I1th5F6eq8UI' data, err = require('socket.http').request(url) if not data then   log('request failed', err)   return end data = data:split('\n') events = {} for _, line in ipairs(data) do   line = line:trim()   if line == 'BEGIN:VEVENT' then     event = {}   elseif line == 'END:VEVENT' then     events[ #events + 1 ] = event     event = nil   elseif event then     pos = line:find(':')     if pos then       key = line:sub(1, pos - 1)       value = line:sub(pos + 1)       event[ key ] = value     end   end end now = os.date('%Y%m%d') summary = '' for _, event in ipairs(events) do   if event['DTSTART;VALUE=DATE'] == now then     summary = event['SUMMARY']     break   end end grp.checkupdate('1/1/1', summary)
RE: garbage can trigger - pioneersteffen - 17.01.2022
Hi Admin,
many thanks for your help! Highly appreciated!
Two questions:
The content of the variable data. Do I need just to replace „\n“ with the copy and paste text string out of the ics opened by a text editor? I tried to and getting failure messages. Or do you have a recommendation how to convert it?
Would it be also possible to parse it directly from a webcal address?
Best Regards
Steffen
RE: garbage can trigger - admin - 18.01.2022
What is the URL to get the ICS file?
RE: garbage can trigger - pioneersteffen - 18.01.2022
Here is a test url:
webcal://p35-caldav.icloud.com/published/2/MTQzMzA1NjcxOTE0MzMwNXFFkpAlN-RmUw02iYPAHdjXli1qufT3m2kVvFAFS2VXJLUhJ6r02NrhV15B8p_WoReJ0k5wrU4I1th5F6eq8UI
I've modified my original example to fetch ICS from the URL.
Awesome! It works! Many thanks for all of your help!
@admin: If I want to get a message today for a planned pickup tomorrow, how is the modification look like? Sorry for the rookie question I‘ve tried to find a solution via search function without any success.
Replace line 32 with this:
now = os.date('%Y%m%d', os.time() + 86400)
Awesome! Many thanks again! :-)
