MQTT user library - Printable Version
+--- Thread: MQTT user library (/showthread.php?tid=3796)
MQTT user library - mdisilvestro - 06.01.2022
someone can post user MQTT library?
Probably I unfortunaly delete it
Thank you
RE: MQTT user library - Daniel - 06.01.2022
It is part of the firmware, re-install the firmware.
RE: MQTT user library - mdisilvestro - 06.01.2022
I tried to install again the last firmware, but unfortunally I can't see the library
if not then you have a corrupted device of some sort, it is there by default.
RE: MQTT user library - admin - 06.01.2022
It's a package not a user library. It is shown in System config > System > Packages
If I reinstall mosquitto packages? I can see them in the library list.
Not any hard event occoured, just accidentally deleted in the user library tab
Can I reinstall the package?
There is no user library supplied in the firmware. As Daniel said, if you have deleted the package you can simply reinstall the firmware.
