HTML widget in mosaic - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: HTML widget in mosaic (/showthread.php?tid=3801) |
HTML widget in mosaic - CristianAgata - 09.01.2022 Hi, Is it possible integrate the status of a virtual object in the HTML widget in mosaic3? For example, I created a text field, is it possible fill it with the value of a virtual object? Best regards Cristian RE: HTML widget in mosaic - admin - 14.01.2022 Can you describe what are you trying to achieve? Is this not possible to do with a custom widget? RE: HTML widget in mosaic - CristianAgata - 14.01.2022 (14.01.2022, 12:00)admin Wrote: Can you describe what are you trying to achieve? Is this not possible to do with a custom widget? Ok I think to understand what you want to do, widget creator -> image -> text field..... Ok I think it could be done. Thanks RE: HTML widget in mosaic - CristianAgata - 15.01.2022 (14.01.2022, 12:00)admin Wrote: Can you describe what are you trying to achieve? Is this not possible to do with a custom widget? Hi Admin, I'm working on Widget creator and I think I can do what I want. But an information when I try to insert an image. How can I use an Image on LM folder? I had tried with ../user/image.png but doesn't work. Best regards Cristian RE: HTML widget in mosaic - CristianAgata - 15.01.2022 (15.01.2022, 10:54)CristianAgata Wrote:(14.01.2022, 12:00)admin Wrote: Can you describe what are you trying to achieve? Is this not possible to do with a custom widget? I 've got...... I have found a answer in this post: https://forum.logicmachine.net/showthread.php?tid=2607&highlight=image+on+mosaic best regards Cristian |
