Mosaic cloud - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Mosaic cloud (/showthread.php?tid=3804) |
Mosaic cloud - CristianAgata - 12.01.2022 Hi, Is there a way to force the cloud update by script? Best regards Cristian RE: Mosaic cloud - Daniel - 12.01.2022 Do you mean sync cloud app? Why do you ask? RE: Mosaic cloud - CristianAgata - 12.01.2022 (12.01.2022, 11:45)Daniel Wrote: Do you mean sync cloud app? Why do you ask? Yes, because the cloud seems update ( green dot ) on the log visualize connect, but doesn't update and send telegram. To make the cloud work again I need to press sync on the app and it works again without problems. It happens always after a power supply failure (main line) Best regards Cristian RE: Mosaic cloud - admin - 12.01.2022 Does the same thing happen if you reboot LM via System config? RE: Mosaic cloud - CristianAgata - 12.01.2022 (12.01.2022, 11:51)admin Wrote: Does the same thing happen if you reboot LM via System config? I need to check. Best regards Cristian RE: Mosaic cloud - CristianAgata - 13.01.2022 (12.01.2022, 11:51)admin Wrote: Does the same thing happen if you reboot LM via System config? Yes, I have tested and I confirm that it does after a reboot from system config too. Best regards Cristian RE: Mosaic cloud - admin - 14.01.2022 An updated LM cloud app has been published, see if it fixes the issue for you RE: Mosaic cloud - CristianAgata - 14.01.2022 (14.01.2022, 11:57)admin Wrote: An updated LM cloud app has been published, see if it fixes the issue for you Thanks I will make tomorrow and I let you know. Best regards Cristian |
