Storing Long Access Tokens - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Storing Long Access Tokens (/showthread.php?tid=3824) |
Storing Long Access Tokens - jamesng - 25.01.2022 Hi I need to store a user-updatable / logic machine script-updateable access token which is approx 2600 characters long. I would normally store this type of value as a User Parmeter however the string datatype here is only 255 bytes. Short of hard coding this into a script, is there any other way that I can store this token? Directly in the database perhaps? Im running SHAC firmware 1.10.0. Many thanks in advance Kind Regards James RE: Storing Long Access Tokens - Daniel - 25.01.2022 Why don't you use storage? RE: Storing Long Access Tokens - jamesng - 25.01.2022 Thanks pointing me to use storage .. I've always overlooked storage.set() .. It's the perfect solution! Kind Regards James RE: Storing Long Access Tokens - jamesng - 26.01.2022 Is there way to browse all stored data (without knowing a specific key that's been used to identify the stored info)? Kind Regards James RE: Storing Long Access Tokens - admin - 26.01.2022 You can use storage.all() and storage.keys() for this. In LM there's a storage viewer app which can be used instead of scripts. RE: Storing Long Access Tokens - jamesng - 26.01.2022 Many thanks for the scripted solution - these work well Is there now a way to install apps on the Schneider SHAC version (firmware Version: 1.10.0) of LogicMachine? Kind Regards James RE: Storing Long Access Tokens - Daniel - 26.01.2022 No |
