Export Access Logs - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Export Access Logs (/showthread.php?tid=3835) |
Export Access Logs - anagno@bluewin.ch - 30.01.2022 I would like to export the Wiser's Access Logs. Is this possible? RE: Export Access Logs - admin - 31.01.2022 Use this to export to CSV. Then you can upload it to FTP, send via e-mail etc. Code: rows = {
'"date","login","ip","failed"'
items = db:getall('SELECT * FROM user_logs ORDER BY id DESC')
for _, item in ipairs(items) do
date = os.date('%Y.%m.%d %H:%M:%S', item.created)
failed = toboolean(item.failed)
rows[ #rows + 1 ] = string.format('%q,%q,%q,%q',
date,
item.login or '?',
item.ip or '?',
failed and 'yes' or 'no'
csv = table.concat(rows, '\n')RE: Export Access Logs - anagno@bluewin.ch - 31.01.2022 excellent! thank you very-very much |
