javascript group read - Printable Version
+--- Thread: javascript group read (/showthread.php?tid=3853)
javascript group read - jmir - 03.02.2022
Is there any way to send group read telegrams from javascript?
Is there any documentation where I can see which knx bus functions are available using javascript?
RE: javascript group read - admin - 03.02.2022
Full list of functions: https://forum.logicmachine.net/showthread.php?tid=321
Since read is not available at the moment you can use this:
var req = { action: 'read', address: '1/1/1' }; localbus.ws.send(JSON.stringify(req));
RE: javascript group read - jmir - 03.02.2022
(03.02.2022, 14:28)admin Wrote: Full list of functions: https://forum.logicmachine.net/showthread.php?tid=321
Ok thanks!!
Ok thanks!!
I've tested and it says localbus.ws is not defined...
RE: javascript group read - admin - 04.02.2022
You are probably calling it before localbus is connected.
Try this:
$(localbus).on('connect', function() {   console.log('connected');   var req = { action: 'read', address: '1/1/1' };   localbus.ws.send(JSON.stringify(req)); });
RE: javascript group read - jmir - 04.02.2022
(04.02.2022, 08:42)admin Wrote: You are probably calling it before localbus is connected.
Try this:
Ok, now it works!
Thanks!
