DMX Speed - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: DMX Speed (/showthread.php?tid=3854) |
DMX Speed - DGrandes - 04.02.2022 Hi, I´m working with DMX lighting of a bridge and I have some problems with the final solution. They want to do some animations with lights and speedo of DMX not work fine, I don´t know if the problem is Logic Machine Script or DMX lights. An example: I have 52 RGBW lights and I want to write a color individually in each light. Code: for i = 1, 52, 1 do
grp.update(dir[i], color)
os.sleep(time)
endIt i put 1 in time, it work perfectly, but with 500ms, it write in 2 lights at once,with 250ms, it write in 4 lights at once.... I think there is a limitation in the communication of 1 second. Default params: Code: local defaults = {
-- storage key
skey = 'dmx_line_1',
-- RS-485 port
port = '/dev/RS485-2',
-- number of calls per second
resolution = 20, -- default 20
-- total number of channels to use
channels = 256,
-- transition time in seconds, does not include DMX transfer time
transition = 1,
}I tried to change resolution in params to 200 but doesn´t work, it works worse. Any ideas? Thanks! RE: DMX Speed - admin - 04.02.2022 The library reads values once a second. If you want some custom animation you should use the DMX library directly without using groups in between. RE: DMX Speed - Punchito - 13.11.2023 (04.02.2022, 10:14)admin Wrote: The library reads values once a second. If you want some custom animation you should use the DMX library directly without using groups in between. Could you give an example? RE: DMX Speed - Daniel - 13.11.2023 https://openrb.com/example-dmx-lighting-control-with-lm2/ RE: DMX Speed - Punchito - 14.11.2023 (13.11.2023, 15:48)Daniel Wrote: https://openrb.com/example-dmx-lighting-control-with-lm2/ In this example, changes occur once per second, I need it faster. How can I implement this? RE: DMX Speed - admin - 14.11.2023 You need to use low-level library functions. Resident script example for 2 channels: Code: dmx = require('luadmx').open('/dev/RS485-1')
dmx:setcount(2)
function send(val)
dmx:setchannel(1, val)
dmx:setchannel(2, 255 - val)
dmx:send()
os.sleep(0.1)
while true do
for val = 0, 255, 5 do
send(val)
for val = 250, 5, -5 do
send(val)
end |
