Modbus error CRC - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus error CRC (/showthread.php?tid=3885) |
Modbus error CRC - CristianAgata - 19.02.2022 Hi everybody, I've this error (see attached file) on a modbus system. Any suggest? RE: Modbus error CRC - admin - 21.02.2022 This usually means there's a problem on the physical bus level. Make sure that parity and stop bits settings are correct. Check if GND is connected between LM and the Modbus device. A termination resistor might be needed as well. Also check AC polarity on both LM and the Modbus device. There was a report where one of the power supplies has AC polarity connected in reverse and this caused communication issues. |
