High load averages - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: High load averages (/showthread.php?tid=3887) |
High load averages - anagno@bluewin.ch - 20.02.2022 Why is having high loads (e.g.: "Load averages: 1.84 1.19 1.20") problematic? what may happen? its it essential to attempt to reduce the load? RE: High load averages - Dré - 20.02.2022 Try LM app Processes to have a better view watch process use more sources RE: High load averages - anagno@bluewin.ch - 20.02.2022 (20.02.2022, 16:19)Dré Wrote: Try LM app Processes to have a better view watch process use more sources Thank you, but I would be interested to know what happens if I fail to identify the process. Why is problematic having a high load? What will be the potential problems if I fail to fix this issue? RE: High load averages - admin - 21.02.2022 You get worse performance because the CPU is busy with other tasks. This can also shorten the device lifespan if it's always running at 100% load which causes higher internal temperature levels. RE: High load averages - anagno@bluewin.ch - 21.02.2022 Thanks - I understand. Wiser shows currently a CPU temperature of 80-82 °C. Is this OK or rather high? RE: High load averages - admin - 21.02.2022 This is more or less ok. What is your CPU load in %? RE: High load averages - pioneersteffen - 23.02.2022 Are you using the Cloud connector and IoT T3 API App on your Wiser? This causes really high load. Try the process app to evaluate the reason. I contacted Schneider Electric regarding the apps load but never got an answer. RE: High load averages - Erwin van der Zwart - 24.02.2022 We are aware of higher load (mostly on older HW1) and are currently testing performance improved versions of API T3 and Cloud Connector apps, they will be available after testing period.. Next to that we are testing the fully new app for Wiser for KNX that will replace the old one, this app is using API T3 and Cloud Connector hence the tests above.. I have no ETA for the releases.. RE: High load averages - anagno@bluewin.ch - 24.02.2022 (21.02.2022, 08:38)admin Wrote: This is more or less ok. What is your CPU load in %? Dear admin Currently the load average is "0.37 0.58 0.58", which is OK, and the temperature 78.4°C. But the load average, particularly the first number, experiences frequently fluctuations (up to > 2 sometimes, increasing the other two numbers ton about 1 or more). Kind regards Georg (23.02.2022, 19:11)pioneersteffen Wrote: Are you using the Cloud connector and IoT T3 API App on your Wiser? This causes really high load. Try the process app to evaluate the reason. No, I don't use the Cloud connector nor the IoT T3 API App |
