Pin code menu - Printable Version
+--- Thread: Pin code menu (/showthread.php?tid=3888)
Pin code menu - jmir - 21.02.2022
Is there any way to open the pin code menu of an object when you enter in the page without clicking the object?
Or some kind of ping code menu that can be used as "inline in usermode"?
RE: Pin code menu - Daniel - 21.02.2022
You can add PIN to the page then you will be asked while accessing this page
RE: Pin code menu - jmir - 21.02.2022
(21.02.2022, 08:25)Daniel Wrote: You can add PIN to the page then you will be asked while accessing this page
I've seen, but I need that when the pin is correct send a value to the bus... (without touching any other button)
RE: Pin code menu - admin - 21.02.2022
This JS will click every element with autoclick class on plan change (won't trigger when the first default plan is shown):
$(function(){   $(document.body).on('showplan', function(e, id) {     $('#plan-' + id).find('.autoclick').click();   }); });
You can also hide these elements if needed via CSS:
.autoclick {   visibility: hidden;   }
(21.02.2022, 08:59)admin Wrote: This JS will click every element with autoclick class on plan change (won't trigger when the first default plan is shown):
Thank you, it works!!
But it's possible to apply to the first default plan?
Use this:
$(function(){   $(document.body).on('showplan', function(e, id) {     $('#plan-' + id).find('.autoclick').click();   }).trigger('showplan', currentPlanId); });
(21.02.2022, 12:54)admin Wrote: Use this:
Perfect! Thanks!
