Schedulers Customization - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Schedulers Customization (/showthread.php?tid=3890) |
Schedulers Customization - manos@dynamitec - 21.02.2022 Hello All, I would like to ask about some things if possible to customize with a custom css code on the schedulers / Holidays form.
Is there a bug known for Spacelynk FW 2.3.0 where the option run/do not run on holidays is not working? I have this report from the client. Is it safe to update the Spacelynk to the latest FW version as this is an industrial application and cannot have fails? Thank you in advance for the support. RE: Schedulers Customization - admin - 21.02.2022 This is not possible at the moment. Points 1 and 2 are easy to implement but will require new firmware. Firmware upgrade is generally safe but make sure that you have latest backup. In rare cases users can discover that the micro SD card is in read-only state because the firmware did not change after the upgrade. So if you want to be 100% sure you should have a replacement micro SD card just in case. RE: Schedulers Customization - manos@dynamitec - 21.02.2022 Hello Admin, FW 2.7.0 will be installed on my next visit on-site. Could you please add here the custom css for point 1-2? Thank you again for the great support. RE: Schedulers Customization - admin - 21.02.2022 For this you will have to wait for a new firmware release after 2.7.0 A possible work-around for point 1 is to create a user that only has access to holidays. RE: Schedulers Customization - JoWo - 21.12.2024 Hello admin is there any news about this topic? Is it possible to show the holidays without any other schedulers or is there a direct link like for the schedulers. I want to show only the holidays on a extra visualization page. my experience is a better ausability if the holidays is on extra page. RE: Schedulers Customization - manos@dynamitec - 21.12.2024 (21.12.2024, 09:43)JoWo Wrote: Hello admin Hello JoWo, I've done this by copying the direct link of the schedulers but in the end change the number to one that does not exist. It's kind of a nice bug which then points you directly to the holidays calendar. Regards |
