RE: Weather Info from API - fabiorusco - 31.10.2022
i nedd to know how may mm of rain done. I modify the script:
require('json')
https = require('ssl.https')
escape = require('socket.url').escape
key = 'xxxxxxxxxxxx'
location = 'Mandello del Lario'
latitude = 45.921373
longitude = 9.314482
args = 'lat=' .. latitude .. '&lon=' .. longitude
url = 'https://api.apixu.com/v1/forecast.json?key=%s&q=%s&days=2'
url = string.format(url, key, escape(arg))
res = https.request(url)
data = json.pdecode(res)
if type(data) ~= 'table' then
alert('Informazioni meteo non pervenute')
return
if data.error then
log('error', data.error)
return
current = data.current
today = data.forecast.forecastday[ 1 ].day
tomorrow = data.forecast.forecastday[ 2 ].day
-- log(current, today, tomorrow)
-- temperature in C
grp.write('32/2/1', current.temp_c)
-- total precipitation in millimeters
grp.write('32/2/8', today.totalprecip_mm)
But don't function. Can someone help me please.
RE: Weather Info from API - RomansP - 31.10.2022
Hello, fabiorusco!
I have added one more object to my script for api.met.no (it is free, no need for special key, you can monitor weather for tomorrow and after tomorrow).
Here are changes what I have added
Code: local status_precipitation_amount_6h = grp.create({ datatype = dt.float16, address = '33/1/28', name = 'precipitation_amount_6h',}) -- mm for next 6 hours
local precipitation_amount_6h = -1 -- participation amount in mm next 6 hours
-- for weather now
if entry.time == timestamp_current_hour then -- get data only for one hour (current hour)
current_data = entry.data.instant.details
if type(current_data) == 'table' then
temperature_YR = current_data.air_temperature or -273 -- temperature in Celsius degree
air_pressure_YR = current_data.air_pressure_at_sea_level or -1 -- air pressure in hPa
humidity_YR = current_data.relative_humidity or -1 -- air humidity in %
wind_direction_YR = current_data.wind_from_direction or -1 -- wind direction in degrees [0;360)
wind_speed_YR = current_data.wind_speed or -1 -- wind speed in m/s
uv_index_YR = current_data.ultraviolet_index_clear_sky or -1 -- uv index
feelslike_temp_YR = calc_feelslike(temperature_YR, wind_speed_YR, humidity_YR) -- feels like temperature in Celsius degree
next_6h = entry.data.next_6_hours.details
if type(next_6h) == 'table' then
precipitation_amount_6h = next_6h.precipitation_amount or -1 -- precipitation amount in mm, next 6 hours
grp.write(status_precipitation_amount_6h, precipitation_amount_6h) -- precipitation mm for next 6 hours
And here the whole script:
Code: local status_temp = grp.create({ datatype = dt.float16, address = '33/1/1', name = 'current_temp',})
local status_pressure = grp.create({ datatype = dt.uint16, address = '33/1/2', name = 'current_press',})
local status_humidity = grp.create({ datatype = dt.scale, address = '33/1/3', name = 'current_humid',})
local status_wind_direction = grp.create({ datatype = dt.float16, address = '33/1/4', name = 'current_wind_dir',})
local status_wind_speed = grp.create({ datatype = dt.float16, address = '33/1/5', name = 'current_wind_sp',})
local status_uv_index = grp.create({ datatype = dt.uint8, address = '33/1/6', name = 'current_uv_index',})
local status_feelslike_temp = grp.create({ datatype = dt.float16, address = '33/1/7', name = 'current_feels_temp',})
local status_rain_today = grp.create({ datatype = dt.bool, address = '33/1/8', name = 'rain_today',})
local status_snow_today = grp.create({ datatype = dt.bool, address = '33/1/9', name = 'snow_today',})
local status_min_temp_today = grp.create({ datatype = dt.float16, address = '33/1/10', name = 'today_temp_min',})
local status_max_temp_today = grp.create({ datatype = dt.float16, address = '33/1/11', name = 'today_temp_max',})
local status_min_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/12', name = 'today_press_min',})
local status_max_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/13', name = 'today_press_max',})
local status_min_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/14', name = 'today_wind_min',})
local status_max_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/15', name = 'today_wind_max',})
local status_min_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/16', name = 'today_uv_min',})
local status_max_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/17', name = 'today_uv_max',})
local status_rain_tomor = grp.create({ datatype = dt.bool, address = '33/1/18', name = 'rain_tomor',})
local status_snow_tomor = grp.create({ datatype = dt.bool, address = '33/1/19', name = 'snow_tomor',})
local status_min_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/20', name = 'tomor_temp_min',})
local status_max_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/21', name = 'tomor_temp_max',})
local status_min_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/22', name = 'tomor_press_min',})
local status_max_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/23', name = 'tomor_press_max',})
local status_min_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/24', name = 'tomor_wind_min',})
local status_max_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/25', name = 'tomor_wind_max',})
local status_min_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/26', name = 'tomor_uv_min',})
local status_max_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/27', name = 'tomor_uv_max',})
local rain_tod_YR = false -- is rainy or not (for today)
local snow_tod_YR = false -- is snowy or not (for today)
local rain_tom_YR = false -- is rainy or not (for tomorrow)
local snow_tom_YR = false -- is snowy or not (for tomorrow)
-- current temperature, air pressure, humidity, wind direction and speed
local temperature_YR = -273 -- temperature in degree Celsius
local air_pressure_YR = -1 -- air pressure in hPa
local humidity_YR = -1 -- air humidity in %
local wind_direction_YR = -1 -- wind direction in degrees [0; 360)
local wind_speed_YR = -1 -- wind speed in m/s
local uv_index_YR = -1 -- UV index
local feelslike_temp_YR = -273 -- feels like temperature in degree Celsius
function init_min_max_table() -- initialize table for minimum, maximum temperature, pressure, windspeed
local min_max = {}
min_max.min_t = 8000 -- minimum temperature for today
min_max.max_t = -273 -- maximum temperature for today
min_max.min_p = 8000 -- minimum pressure for today
min_max.max_p = -1 -- maximum pressure for today
min_max.min_w = 8000 -- minimum wind speed for today
min_max.max_w = -1 -- maximum wind speed for today
min_max.min_uv = 8000 -- minimum UV index
min_max.max_uv = -1 -- maximum UV index
return min_max
function set_timestamp(day) -- if day = 0 today; if day = 1 tomorrow, if day = 2 day after tomorrow
local date = os.date('*t')
date.day = date.day + day
local time = os.time(date)
return os.date('%Y-%m-%d', time), date.hour -- timestamp and current hour
-- minimum maximum values of temperature, pressure and windspeed
function min_max_temp_press_wind(dat_tab, min_max_tab)
min_max_tab.min_t = math.min(min_max_tab.min_t, dat_tab.air_temperature or 8000)
min_max_tab.max_t = math.max(min_max_tab.max_t, dat_tab.air_temperature or -273)
min_max_tab.min_p = math.min(min_max_tab.min_p, dat_tab.air_pressure_at_sea_level or 8000)
min_max_tab.max_p = math.max(min_max_tab.max_p, dat_tab.air_pressure_at_sea_level or -1)
min_max_tab.min_w = math.min(min_max_tab.min_w, dat_tab.wind_speed or 8000)
min_max_tab.max_w = math.max(min_max_tab.max_w, dat_tab.wind_speed or -1)
min_max_tab.min_uv = math.min(min_max_tab.min_uv, dat_tab.ultraviolet_index_clear_sky or 8000)
min_max_tab.max_uv = math.max(min_max_tab.max_uv, dat_tab.ultraviolet_index_clear_sky or -1)
return min_max_tab
function check_for_rain(next1h)
local is_rainy = false
local code = ''
if type(next1h) == 'table' and type(next1h.summary) == 'table' then
code = next1h.summary.symbol_code or ''
if code:find('rain') then
is_rainy = true
return is_rainy
function check_for_snow(next1h)
local is_snowy = false
local code = ''
if code:find('snow') then
is_snowy = true
return is_snowy
function calc_heat_index(temperature, humidity)
if temperature < 26.7 then
log('for heat_index calculation temperature should be higher than +26.7 Celsius degree')
return -273
if humidity < 0 or humidity > 100 then
log('humidity should be in a range from 0 ... 100%')
return -273
local T = temperature
local H = humidity
local c_1 = -8.785
local c_2 = 1.611
local c_3 = 2.339
local c_4 = -0.146
local c_5 = -0.0123
local c_6 = -0.0164
local c_7 = 0.00221
local c_8 = 0.000725
local c_9 = -0.00000358
local heat_index = c_1+c_2*T+c_3*H+c_4*T*H+c_5*T*T+c_6*H*H+c_7*T*T*H+c_8*T*H*H+c_9*T*T*H*H
return heat_index
function calc_wind_chill(temperature, wind_speed)
if temperature > 10 then
log('temperature should be less than +10.0 Celsius degree')
return -273
if wind_speed < 0 or wind_speed > 49.2 then
log('wind speed should be in a range 0 ... 49.2 m/s')
return -273
local T_air = temperature -- air temperature Celsius degree
local a = 0.62 -- coef
local b = 0.51 -- coef
local T_1 = 13.1 -- Celsius degree
local T_2 = 14.6 -- Celsius degree
local M_0 = 1.3333 -- m/s
local M = wind_speed -- m/s
local T_wind_chill
if M > M_0 then
T_wind_chill = (a*T_air + T_1) + (b*T_air - T_2)*(M/M_0)^0.16
T_wind_chill = T_air
return T_wind_chill
function calc_feelslike(temperature, wind_speed, humidity)
local T_feelslike
if temperature <= 10.0 then -- if less than 10.0 Celsius degree (or equal) then wind chill
T_feelslike = calc_wind_chill(temperature, wind_speed)
elseif temperature >= 26.7 then -- if more than 26.7 Celsius degree (or equal) then heat index
T_feelslike = calc_heat_index(temperature, humidity)
else -- other cases just return temperature
T_feelslike = temperature
return T_feelslike
local min_max_today = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction
local min_max_tomor = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction
--local latitude = 51.5072 -- 'London'
--local longitude = 0.1276 -- 'London'
local latitude = 45.921373 -- 'Mandello del Lario'
local longitude = 9.314482 -- 'Mandello del Lario'
json = require('json')
ltn12 = require('ltn12')
url = 'https://api.met.no/weatherapi/locationforecast/2.0/complete?' .. args
mac = 0
io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)
mac = mac * 256 + tonumber(v, 16)
end)
response = {}
res, code = https.request({
url = url,
protocol = 'tlsv12',
headers = {
['user-agent'] = 'LM ' .. mac
sink = ltn12.sink.table(response)
if res and code == 200 then
data = json.pdecode(table.concat(response))
log('request error', res, code)
if type(data) == 'table' then
timestamp, hour = set_timestamp(0) -- current day
if hour < 10 then
timestamp_current_hour = timestamp .. 'T0' .. hour .. ':00:00Z' -- time stamp for current hour
timestamp_current_hour = timestamp .. 'T' .. hour .. ':00:00Z' -- time stamp for current hour
--log('timestamp = ' .. timestamp)
timestamp_next = set_timestamp(1) -- timestamp for tomorrow
--log('timestamp_next = ' .. timestamp_next)
--timestamp_after_next = set_timestamp(2) -- timestamp for day after tomorrow
--log('timestamp_after_next = ' .. timestamp_after_next)
--timestamp_after_after = set_timestamp(3) -- timestamp for day after day after tomorrow
--log('timestamp_after_after = ' .. timestamp_after_after)
for i, entry in ipairs(data.properties.timeseries) do
-- for weather now
if entry.time:sub(1, #timestamp) == timestamp then -- checks remaining hours + 3 previous hours of current day
min_max_today = min_max_temp_press_wind(current_data, min_max_today)
if rain_tod_YR == false then -- if detected rain does not check for rain
rain_tod_YR = check_for_rain(entry.data.next_1_hours)
if snow_tod_YR == false then -- if detected snow does not check for snow
snow_tod_YR = check_for_snow(entry.data.next_1_hours)
if entry.time:sub(1, #timestamp_next) == timestamp_next then -- checks 24 hours of next day
tomor_data = entry.data.instant.details
if type(tomor_data) == 'table' then
min_max_tomor = min_max_temp_press_wind(tomor_data, min_max_tomor)
if rain_tom_YR == false then -- if detected rain does not check for rain
rain_tom_YR = check_for_rain(entry.data.next_1_hours)
if snow_tom_YR == false then -- if detected snow does not check for snow
snow_tom_YR = check_for_snow(entry.data.next_1_hours)
-- data for current hour
grp.write(status_temp, temperature_YR)
grp.write(status_pressure, air_pressure_YR)
grp.write(status_humidity, humidity_YR)
grp.write(status_wind_direction, wind_direction_YR)
grp.write(status_wind_speed, wind_speed_YR)
grp.write(status_uv_index, uv_index_YR)
grp.write(status_feelslike_temp, feelslike_temp_YR)
-- data for today: rain, snow; min and max for temperature, pressure, wind
grp.write(status_rain_today, rain_tod_YR)
grp.write(status_snow_today, snow_tod_YR)
grp.write(status_min_temp_today, min_max_today.min_t)
grp.write(status_max_temp_today, min_max_today.max_t)
grp.write(status_min_pressure_today, min_max_today.min_p)
grp.write(status_max_pressure_today, min_max_today.max_p)
grp.write(status_min_wind_speed_today, min_max_today.min_w)
grp.write(status_max_wind_speed_today, min_max_today.max_w)
grp.write(status_min_uv_today, min_max_today.min_uv)
grp.write(status_max_uv_today, min_max_today.max_uv)
-- data for tomorrow: rain, snow; min and max for temperature, pressure, wind
grp.write(status_rain_tomor, rain_tom_YR)
grp.write(status_snow_tomor, snow_tom_YR)
grp.write(status_min_temp_tomor, min_max_tomor.min_t)
grp.write(status_max_temp_tomor, min_max_tomor.max_t)
grp.write(status_min_pressure_tomor, min_max_tomor.min_p)
grp.write(status_max_pressure_tomor, min_max_tomor.max_p)
grp.write(status_min_wind_speed_tomor, min_max_tomor.min_w)
grp.write(status_max_wind_speed_tomor, min_max_tomor.max_w)
grp.write(status_min_uv_tomor, min_max_tomor.min_uv)
grp.write(status_max_uv_tomor, min_max_tomor.max_uv)
RE: Weather Info from API - fabiorusco - 03.11.2022
(31.10.2022, 13:48)RomansP Wrote: Hello, fabiorusco!
-- for weather now
local min_max = {}
return min_max
return min_max_tab
local code = ''
is_rainy = true
return is_rainy
local code = ''
is_snowy = true
return is_snowy
return -273
return -273
local H = humidity
local c_1 = -8.785
local c_2 = 1.611
local c_3 = 2.339
local c_4 = -0.146
local c_5 = -0.0123
local c_6 = -0.0164
local c_7 = 0.00221
return heat_index
return -273
return -273
local T_wind_chill
if M > M_0 then
return T_wind_chill
local T_feelslike
return T_feelslike
mac = 0
end)
response = {}
url = url,
headers = {
if hour < 10 then
-- for weather now
Thank you,
good help for me.
Best regards
Fabio
(03.11.2022, 06:51)fabiorusco Wrote: (31.10.2022, 13:48)RomansP Wrote: Hello, fabiorusco!
-- for weather now
local min_max = {}
return min_max
return min_max_tab
local code = ''
is_rainy = true
return is_rainy
local code = ''
is_snowy = true
return is_snowy
return -273
return -273
local H = humidity
local c_1 = -8.785
local c_2 = 1.611
local c_3 = 2.339
local c_4 = -0.146
local c_5 = -0.0123
local c_6 = -0.0164
local c_7 = 0.00221
return heat_index
return -273
return -273
local T_wind_chill
if M > M_0 then
return T_wind_chill
local T_feelslike
return T_feelslike
mac = 0
end)
response = {}
url = url,
headers = {
if hour < 10 then
-- for weather now
Thank you,
good help for me.
Best regards
Fabio
how it's possible to know the total precipitation of today?
Is it good also for Italy ? (the service is located in scandinavian zone)
RE: Weather Info from API - RomansP - 03.11.2022
Hello.
I have added calculation of precipitation amount of current day (gives you precipitation amount of remaining day + 3 previous hours of current day).
It is also suitable for Italy (have checked with Rome coordinates).
local status_precipitation_amount_today = grp.create({ datatype = dt.float16, address = '33/1/29', name = 'precipitation_amount_today',}) -- mm for current day + 3 previous hours
local precipitation_amount_today = 0 -- participation amount in mm for current day + 3 previous hours
local min_max = {}
return min_max
return min_max_tab
local code = ''
is_rainy = true
return is_rainy
local code = ''
is_snowy = true
return is_snowy
return -273
return -273
local H = humidity
local c_1 = -8.785
local c_2 = 1.611
local c_3 = 2.339
local c_4 = -0.146
local c_5 = -0.0123
local c_6 = -0.0164
local c_7 = 0.00221
return heat_index
return -273
return -273
local T_wind_chill
if M > M_0 then
return T_wind_chill
local T_feelslike
return T_feelslike
mac = 0
end)
response = {}
url = url,
headers = {
if hour < 10 then
-- for weather now
precipitation_amount_today = precipitation_amount_today + (entry.data.next_1_hours.details.precipitation_amount or 0)
grp.write(status_precipitation_amount_today, precipitation_amount_today) -- precipitation mm for today (remaining day + 3 previous hours)
Thank you.
RE: Weather Info from API - P_marienborg - 17.01.2023
Hello.
I have tried the latest version on my spacelynk with vr 2.8.0
I am getting this error in the log:
* arg: 1
* string: request error
* arg: 2
* nil
* arg: 3
* string: Try again
Could someone point me in the right direction?
I think it something here that's not right:
mac = 0
end)
This is the only changes I have done:
--local latitude = 69.6489 -- 'Tromso'
--local longitude = 18.95508 -- 'Tromso'
RE: Weather Info from API - admin - 17.01.2023
Check that you have correct gateway and DNS settings in System config > Network > Interfaces.
RE: Weather Info from API - alias74 - 09.06.2023
is working for me, thanks
