LM5 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: LM5 (/showthread.php?tid=3928) |
LM5 - Fahd - 11.03.2022 After updating my LM5 to lm5m3-20211215, I can't reach it on the network even I made a reset. RE: LM5 - Daniel - 11.03.2022 Were you able to perform HW factory reset and the LEDs reacted correctly? In this case the safest option is to reflash the card https://openrb.com/reflash-logicmachine3-and-streaming-player-software/ RE: LM5 - Fahd - 14.03.2022 How should the LEDs react ? RE: LM5 - Daniel - 14.03.2022 When you hold reset button for first 10s led 2 will be red and it will flash red after 10s, release and press again. After 10sec will flash faster. RE: LM5 - Fahd - 18.03.2022 (14.03.2022, 19:08)Daniel Wrote: When you hold reset button for first 10s led 2 will be red and it will flash red after 10s, release and press again. After 10sec will flash faster. Hi Daniel, When I hold reset button for 10s the led 2 doesn't turn red RE: LM5 - Daniel - 18.03.2022 Does any LED comes on when you power it up? RE: LM5 - Fahd - 18.03.2022 Yes the first led, and it will turn on and off every 2,3s RE: LM5 - Daniel - 18.03.2022 What about second LED? RE: LM5 - Fahd - 18.03.2022 It flashes red every two seconds with very low light RE: LM5 - Daniel - 18.03.2022 Power it down and check again RE: LM5 - Fahd - 18.03.2022 The same thing RE: LM5 - Daniel - 18.03.2022 Re flash the SD card, to be 100% sure you should use new card. |
