DALI 2.0 motion detector - Printable Version
+--- Thread: DALI 2.0 motion detector (/showthread.php?tid=3933)
DALI 2.0 motion detector - tom77 - 14.03.2022
I have a project where Dali 2.0 motion detectors are installed (B.E.G PICO-BMS DALI-2), is there a possibility to receive the 24bit telegrams sent by the motion detectors with the LM ?
Regards
Thomas
RE: DALI 2.0 motion detector - admin - 15.03.2022
LM can receive such telegrams but the parsing has to be done using scripts at the moment. We have plans to implement DALI 2.0 later.
You should also take into account that DALI bus is really slow and it can be easily overloaded if you attach many sensors to a single line.
RE: DALI 2.0 motion detector - tom77 - 15.03.2022
the speed will not be the problem in my case we have few luminaire groups on the dalibus and only a few of these sensors, how can i listen to the bus ? i cannot find the appropriate command, https://openrb.com/docs/dali.htm
thank you
Thomas
At this moment receiving telegrams is only supported via an external CANx-DALI interface. Internal DALI interface on Reactor devices and external RS-485 gateways do not support this.
great I have a canX Dali Gateway, I had overlooked the post https://forum.logicmachine.net/showthread.php?tid=3746&highlight=dali+2 how do I integrate this script?
RE: DALI 2.0 motion detector - admin - 16.03.2022
Resident script with sleep time set to 0. It will log all bus messages in hex format.
if not canxdali then   canxdali = require('applibs.canxdali')   canxdali.getlistener(1) -- 1 second timeout      canxdali.sethandler('busdata', function(msg)     local data = msg.data     loghex(data)   end) end canxdali.step()
RE: DALI 2.0 motion detector - tom77 - 16.03.2022
Perfect, that's enough for me,
thank you very much
RE: DALI 2.0 motion detector - admin - 29.03.2022
Updated CANx-DALI app has been published. It has experimental DALI2 frame parsing which can be used in scripts. Docs: https://openrb.com/docs/canxdali-dali2.htm
