Background color depends on the Value - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Background color depends on the Value (/showthread.php?tid=3946) |
Background color depends on the Value - Fahd - 22.03.2022 Hello Guys, Please, I hope you could help me with that, I have no knowledge with Java or CSS I want to change the background color of Temp Value depending on the Value itself, for example, if the Value is >= 25 then the background color should be Red if it is between 21 and 24.5 then orange and if it's below then blue. Many thanks in advance RE: Background color depends on the Value - admin - 22.03.2022 See this: https://forum.logicmachine.net/showthread.php?tid=1976&pid=20292#pid20292 RE: Background color depends on the Value - stemic01 - 29.03.2022 I am not sure if it 100% relevant for your question but it works fine for my setup giving different background colors related to values. I use the Object "Additional icons" button where you can specify different values and assign corresponding PNGs to it. So I have pre-made some few PNGs in different colors which will change on different values. Very simple setup. |
