did i create a loop - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: did i create a loop (/showthread.php?tid=3956) |
did i create a loop - Dré - 24.03.2022 I have a question, it looks like i create a loop. Now i will understand if my thoughts about this are correct, and what is the best way to solve this? I have 1 script, that's start run by a tag 'Play_Knocks'. Is it true, this script run in a loop, because i ask a read on the same groupadress who has the tag who start this script? I think I can't use 'value = event.getvalue()' because, i have two different logics who can start the sounds Code: PIR_salvage = grp.read('14/0/58') --this got the tag 'Play_Knocks'
Door_salvage = grp.read('14/0/57')
garden_door = grp.read('14/0/42')
PIR_livingroom = grp.read('14/0/28') --this got the tag 'Play_Knocks'
sound_released = grp.read('32/1/21')
if PIR_salvage == true
and Door_salvage == true
and sound_released == true
then grp.write('32/1/22', true) --'Play Sound Knock on Wiser'
elseif
PIR_livingroom == true
and garden_door == true
endRE: did i create a loop - admin - 24.03.2022 Does 32/1/22 have the same tag which is executing the script? RE: did i create a loop - Dré - 24.03.2022 No only PIR_salvage = grp.read('14/0/58') --this got the tag 'Play_Knocks' PIR_livingroom = grp.read('14/0/28') --this got the tag 'Play_Knocks' has the same tag RE: did i create a loop - admin - 24.03.2022 Replace grp.read with grp.getvalue RE: did i create a loop - Dré - 24.03.2022 (24.03.2022, 15:16)admin Wrote: Replace grp.read with grp.getvalue Yes this was the solution. does grp.read trigger the script again because it had the tag on this groupadress too? RE: did i create a loop - admin - 25.03.2022 grp.read can trigger the script if "Execute on group read" is enabled. RE: did i create a loop - Dré - 25.03.2022 Thanks, i dont know where to find this option, i looked for it, but didnt see it, but probably it is enabled RE: did i create a loop - admin - 25.03.2022 In script properties: RE: did i create a loop - Dré - 26.03.2022 Oké, i see i take a look and it was off, like your picture show. but the problem solved when i did do this. (24.03.2022, 15:16)admin Wrote: Replace grp.read with grp.getvalue RE: did i create a loop - admin - 26.03.2022 Then another device replied to the read request which then executed the script again and so on. RE: did i create a loop - Dré - 26.03.2022 I see now i understand my problem, thanks for explaining |
