event start part of the script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: event start part of the script (/showthread.php?tid=3971) |
event start part of the script - Dré - 02.04.2022 I try to find out how i can trigger a part of a script. i think i need to use event.dst. I add tags on the groupsobject who trigger the script. The script have multiple part what to do. If the script is trigger by 1/1/1 i will just run the first part of a script. if it is trigger by 1/1/2 i just run the second part of the script. i think i need to use event.dst and elseif, but don't know how to use it. Somebody who can help me with this? RE: event start part of the script - Erwin van der Zwart - 02.04.2022 if event.dst == '1/1/1' then -- do something elseif event.dst == '1/1/2' then -- do something elseif event.dst == '1/1/3' then -- do something else -- do something when nothing matches event.dst end RE: event start part of the script - Dré - 03.04.2022 Thank you Erwin, is it also posible to use this if '1/1/1' = false? and when 1/1/1 is between 0 and 50 Or can we only use it when it is true? RE: event start part of the script - Erwin van der Zwart - 03.04.2022 Replace — do something with: if event.getvalue() == false then — do something end or value = event.getvalue() if value >= 0 and value <= 50 then — do something end RE: event start part of the script - Dré - 08.05.2022 Thank you Erwin, i will try this. |
