Modbus logging - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Modbus logging (/showthread.php?tid=3973) |
Modbus logging - dave.bolas@se.com - 05.04.2022 Hi, I am reading the active energy delivered from an ION7650 via Modus TCP. I can see the value correctly decoded in the object view, but when I look at the object log view, the Decoded Data, Data Type and Object Data are all showing '--' (The data type in the Object view is 4 byte floating point.) Any suggestions as to what I am doing wrong? Regards Dave RE: Modbus logging - Daniel - 05.04.2022 Can you share a screenshot of the value in object tab and in the Object log tab? Also edit the object and send screen too. RE: Modbus logging - dave.bolas@se.com - 05.04.2022 Screenshots added. I'm on Teamviewer if you want to drive? RE: Modbus logging - Daniel - 05.04.2022 This is read telegram. Set the pool interval to 0. Modbus reading is set in modbus tab under device settings. RE: Modbus logging - dave.bolas@se.com - 05.04.2022 Hi Daniel, Sorry, I don't understand. Please can you explain? Regards Dave RE: Modbus logging - Daniel - 05.04.2022 Go to objects, edit object 5/1/11 and 5/0/10 and set pool interval to 0 RE: Modbus logging - dave.bolas@se.com - 05.04.2022 Done. Now its not logging at all. RE: Modbus logging - admin - 05.04.2022 Check Error log in the Modbus tab. RE: Modbus logging - dave.bolas@se.com - 05.04.2022 No errors. But despite the Modbus "Value send delta" being set to 0, it only seems to log when the raw (pre-scaled) value changes by 1. So I get logs at 173,000 then 174,000 etc RE: Modbus logging - admin - 05.04.2022 Even if delta is set to 0 new value is sent only when it differs from the previously sent value. It's possible that the value resolution for this register is 1. RE: Modbus logging - dave.bolas@se.com - 05.04.2022 Brilliant. Thanks. |
