Link Object not showing anymore - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Link Object not showing anymore (/showthread.php?tid=3978) |
Link Object not showing anymore - iJAF - 07.04.2022 Hi, I don't know why, but the link objects do not appear anymore in visualization (plans and layouts) but appear on editing ! (see attachment) I don't know what happened, because the were working fine ! Thank you RE: Link Object not showing anymore - Daniel - 07.04.2022 Does this link actually exists? If not then this is correct behavior. RE: Link Object not showing anymore - iJAF - 07.04.2022 (07.04.2022, 09:48)Daniel Wrote: Does this link actually exists? If not then this is correct behavior. Yes, the link exists, and the navigation link works fine in editor ! I have noticed one strange behaviour, that could be causing this. When I add a new completely blank plan, it generates a new plan #ID, but when I try to access the direct link to the plan, it shows another plans that it is not related ! RE: Link Object not showing anymore - admin - 07.04.2022 Blank plans are not rendered in the viewer. So links might disappear due to this. RE: Link Object not showing anymore - Daniel - 07.04.2022 Just add some object to this plan and all will be fine. RE: Link Object not showing anymore - iJAF - 07.04.2022 (07.04.2022, 10:15)admin Wrote: Blank plans are not rendered in the viewer. So links might disappear due to this. OK, that was the problem, I added a temp text label to the pages and now seems to be showing correctly. Thank you |
