Possible ? Perso Name of object display on the visualisation - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Possible ? Perso Name of object display on the visualisation (/showthread.php?tid=3991) |
Possible ? Perso Name of object display on the visualisation - domotiqa - 13.04.2022 Hi, is there a way to have the personnalize name displayed on visualisation for example certain class or certain object tag or comment at specific position like bottom center ? RE: Possible ? Perso Name of object display on the visualisation - admin - 13.04.2022 Why don't you use text label element for this? RE: Possible ? Perso Name of object display on the visualisation - domotiqa - 13.04.2022 (13.04.2022, 10:31)admin Wrote: Why don't you use text label element for this? in order to spend less time. If I want smartphone view, I need to put the name in personalize name. And also, place Label is still long time spend, and when using CSS class there is still a difference between the area we put it and the render on visualisation (when I put backgroun color, with padding and round...). |
