Getting data from Philips Hue Outdoor Motion Sensor - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Getting data from Philips Hue Outdoor Motion Sensor (/showthread.php?tid=3995) |
Getting data from Philips Hue Outdoor Motion Sensor - Odd Egil Aasheim - 14.04.2022 Hi. Just bought this outdoor sensor from Philips, but struggeling to get some data out where it can be used. I don't want to do something directly inside the Hue system, but to extract data. The device does not come up in http://<ipadress>/api/<userid>/lights along with my other lamps/led's. Instead it is visible http://<ipadress>/api/<userid>/sensors Therefore I tried to modify the user.hue script by adding a section for sensors to search and get data from them. So far so good. This is a snippet from the user.hue script where I have duplicated the code, but renamed the original code from i.e function searchHueLights() to function searchHueSensors() and so on. So "function" 2 and 4 below is new regarding the sensors Code: -- function 1 existing huesearch
local response = {}
body_searchHueLights= ''
-- Set username for LogicMachine
socket.http.request({
url = "http://"..ip_add.."/api/"..user.."/lights",
method = 'POST',
sink = ltn12.sink.table(response),
headers = {
['content-length'] = #body_searchHueLights,
source = ltn12.source.string(body_searchHueLights),
return response
-- function 2 new huesearch
local response = {}
body_searchHueSensors= ''
url = "http://"..ip_add.."/api/"..user.."/sensors",
method = 'POST',
headers = {
['content-length'] = #body_searchHueSensors,
source = ltn12.source.string(body_searchHueSensors),
return response
-- function 3 existing hue datacollection
function getHueLights()
local response = {}
method = 'GET',
headers = {
return response
-- function 4 new hue datacollection
function getHueSensors()
local response = {}
method = 'GET',
headers = {
return response
endBy using this code I then can make a new script for searching Code: require('user.hue')
-- get bridge to search for new lights
result = searchHueLights()
log(result)And a new script for reading data Code: require('user.hue')
-- get all sensordata from bridge
result = getHueSensors()
log(result)Output from Log window, (it all comes in one long line in the log window starting with * string: {... ) Code: Read Hue devices 14.04.2022 17:50:36
* table:
[1]
* string: {"1":{"state":{"daylight":null,"lastupdated":"none"},"config":{"on":true,"configured":false,"sunriseoffset":30,"sunsetoffset":-30},"name":"Daylight","type":"Daylight","modelid":"PHDL00","manufacturername":"Signify Netherlands B.V.","swversion":"1.0"},"2":{"state":{"presence":false,"lastupdated":"2022-04-14T15:29:10"},"swupdate":{"state":"noupdates","lastinstall":"2022-04-13T18:57:32"},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","sensitivity":2,"sensitivitymax":4,"ledindication":false,"usertest":false,"pending":[]},"name":"OutdoorSensor","type":"ZLLPresence","modelid":"SML004","manufacturername":"Signify Netherlands B.V.","productname":"Hue outdoor motion sensor","swversion":"2.53.6","uniqueid":"00:17:88:01:0b:d1:3a:b5-02-0406","capabilities":{"certified":true,"primary":true}},"3":{"state":{"lightlevel":7186,"dark":true,"daylight":false,"lastupdated":"2022-04-14T15:50:23"},"swupdate":{"state":"noupdates","lastinstall":"2022-04-13T18:57:32"},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","tholddark":16000,"tholdoffset":7000,"ledindication":false,"usertest":false,"pending":[]},"name":"Hue outdoor light sensor 1","type":"ZLLLightLevel","modelid":"SML004","manufacturername":"Signify Netherlands B.V.","productname":"Hue outdoor light sensor","swversion":"2.53.6","uniqueid":"00:17:88:01:0b:d1:3a:b5-02-0400","capabilities":{"certified":true,"primary":false}},"4":{"state":{"temperature":2410,"lastupdated":"2022-04-14T15:48:19"},"swupdate":{"state":"noupdates","lastinstall":"2022-04-13T18:57:32"},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","ledindication":false,"usertest":false,"pending":[]},"name":"Hue outdoor temp. sensor 1","type":"ZLLTemperature","modelid":"SML004","manufacturername":"Signify Netherlands B.V.","productname":"Hue outdoor temp. sensor","swversion":"2.53.6","uniqueid":"00:17:88:01:0b:d1:3a:b5-02-0402","capabilities":{"certified":true,"primary":false}}}Let's say that I'm interested in the lightlevel and temperature I can't find the fomat to extract the data for now. Any thoughts how to extract? RE: Getting data from Philips Hue Outdoor Motion Sensor - pioneersteffen - 14.04.2022 Hi, funny thing I just started working on the same topic today. :-) I got it working for the motion state: 1.) Add the following code to the hue user library script: Code: -- function get data from sensors
local response = {}
method = 'GET',
headers = {
return response
end2.) Implement a resident script (example for motion): Code: addressmapping = {
-- Name -- Presence FB
['Hue motion 1'] = {state = '47/2/6', statevalue = ''},
-- Use logging
logging = true
require('user.hue')
require('json')
reply = getHueSensors()
mysensors = json.pdecode(reply[1])
for _, item in pairs(mysensors) do
-- Check if sensor is found by bridge otherwise it make no sense to send commands
if item.config.reachable == true then
-- On/Off
name = addressmapping[item.name]
if name then
addr = addressmapping[item.name]['state']
if addr and addr ~= '' then
currentvalue = addressmapping[item.name]['statevalue']
if currentvalue ~= item.state.presence then
grp.update(addr, item.state.presence)
addressmapping[item.name]['statevalue'] = item.state.presence
if logging == true then
log('sensor ' .. item.name .. ' state is: ' .. tostring(item.state.presence))
endIf you want to have the temperature just looking for the name inside the json e.g. = Hue outdoors temp. sensor 1" and change: "item.state.presence" to "item.state.temperature". This is working I tested it. Due to I just want to have the motion state I didn't implemented it. To get the json "readable" I used: https://jsonformatter.org/json-parser I hope this is helping you. Best Regards Steffen RE: Getting data from Philips Hue Outdoor Motion Sensor - admin - 19.04.2022 In getHueSensors you need to replace return response with return table.concat(response) Then replace mysensors = json.pdecode(reply[1]) with mysensors = json.pdecode(reply) Otherwise your script will start failing if the response becomes larger. |
