Is it possible to show additional icons with decimal values? - Printable Version
+--- Thread: Is it possible to show additional icons with decimal values? (/showthread.php?tid=4007)
Is it possible to show additional icons with decimal values? - Kilogica - 20.04.2022
I want to show three different additional icons for an object, two for values above or below zero and another one when that value is zero.
The problem is that object has two decimals and I can't choose non integer values.
Am I doing something wrong or it isn't possible?
Thank you!
RE: Is it possible to show additional icons with decimal values? - Daniel - 20.04.2022
It is never noticed bug, will be fixed in next version.
RE: Is it possible to show additional icons with decimal values? - Kilogica - 20.04.2022
Thanks, it will be fixed even in Wiser and SpaceLynk?
Yes
Good, thank you!
