script for scene change - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: script for scene change (/showthread.php?tid=4018) |
script for scene change - Vik - 26.04.2022 Hi, I need a script for changing scene’s in a sequence ( scene1 … scene10 ) when we do a short “press-up” or “press-down” on a knx keypad. Example when we short “press-up” the first time scene1 is triggered and it progresses to scene10 on the 10th short press. On the 11th short press scene1 is triggered again . Similarly, when we do a short “press-down” the scene10 to scene9 and so on. In this case when we reach scene1 we jump scene10 after the short “press-down”. thnx vik RE: script for scene change - admin - 26.04.2022 Attach your scenes to 1 byte unsigned object with trigger value from 1 to 10. Create an event script for scene up/down (1 bit). Change scene trigger object (32/1/17) as needed. Code: out = '32/1/17'
up = event.getvalue()
nr = grp.getvalue(out)
if up then
nr = nr + 1
if nr > 10 then
nr = 1
nr = nr - 1
if nr < 1 then
nr = 10
grp.update(out, nr)RE: script for scene change - Vik - 26.04.2022 (26.04.2022, 11:25)Vik Wrote: Hi, Thanks I will try this script Hi, We need your hrlp on another script. We would like to disable a ceiling mount motion sensors whenever we do a "long-press" ( relative dimm). To disable the sensor we need a 1-bit data while the relative dimm is a 4bit data type. We need a script which can disable the sensor whenever a long press is done. regards, vik RE: script for scene change - Daniel - 26.04.2022 Just create event script on the dim object, change group as needed and if the disable value is 0 then change true to false Code: -- write value (e.g. boolean 'true') to object with group address 1/1/1, datatype must be set for this object
grp.write('1/1/1', true)RE: script for scene change - Vik - 28.04.2022 (26.04.2022, 11:35)admin Wrote: Attach your scenes to 1 byte unsigned object with trigger value from 1 to 10. Create an event script for scene up/down (1 bit). Change scene trigger object (32/1/17) as needed. Thank you for this. it worked fine. (26.04.2022, 14:20)Daniel Wrote: Just create event script on the dim object, change group as needed and if the disable value is 0 then change true to false Thanks a lot for this. This worked fine too. |
