Device programming - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: CANx (https://forum.logicmachine.net/forumdisplay.php?fid=23) +--- Thread: Device programming (/showthread.php?tid=4045) |
Device programming - gtsamis - 16.05.2022 Hi, I am having trouble to setup some CanX devices i had from the promo kit. When i try to write device address via the CANx app, the procedure stucks on "Now press the programming button on the device". Line scan also does not find any devices. I have tryied on diferent devices, browsers, PC's without success. I also tryied to flash new software on the CANx devices but again my PC's fails to correctly recognize the USB device . My hardware: LM5p2-KC, CAN-R4-LoRa, CAN-UIO8-LoRa, PC's running Windows 10 & Windows 11 Any thoughts? RE: Device programming - Daniel - 16.05.2022 Most likely you must flash the devices to latest firmware. In the location on your PC where DFU is installed there is pdf file which explains how to install the drivers. Try to fallowing this. How to flash you can see here: https://www.youtube.com/watch?v=t1tn8qZyj1M |
