Data type changed after import in SL - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Data type changed after import in SL (/showthread.php?tid=4059) |
Data type changed after import in SL - khalil - 25.05.2022 Hello When I import KNXProj File data type changed! While when import as ESF data type didnt changed Please see attached images RE: Data type changed after import in SL - Daniel - 25.05.2022 This must be some ETS issue, can you share your ETS project? RE: Data type changed after import in SL - khalil - 25.05.2022 (25.05.2022, 09:47)Daniel Wrote: This must be some ETS issue, can you share your ETS project? How Could I Attache file in PM? RE: Data type changed after import in SL - Daniel - 25.05.2022 Use https://wetransfer.com/ or similar RE: Data type changed after import in SL - khalil - 25.05.2022 (25.05.2022, 09:57)Daniel Wrote: Use https://wetransfer.com/ or similar Sent TO PM |
