Log only objects changes / remove storage files - Printable Version
+--- Thread: Log only objects changes / remove storage files (/showthread.php?tid=406)
Log only objects changes / remove storage files - gtsamis - 02.10.2016
Good evening,
I need some help regarding object logging.
I have some objects that frequently sends group writes even without a value change.
Those objects are logged on the LM's Object Log and I am ending up with a bunch of records without any changes.
Is there any way that the logging will only happen if the object changes it's value?
Also can someone point the storage file location in order to remove unused ones?
Thank you in advance
George
RE: Log only objects changes / remove storage files - admin - 03.10.2016
The only solution that I see is that you create another object for each one you want to log and then filter the input value in an event script.
Add this to Common functions:
function checkupdate(sendto, mindelta)   -- event value   local newvalue = event.getvalue()   -- current object value   local curvalue = grp.getvalue(sendto)   -- absolute delta between event and current value   local valdelta = math.abs(curvalue - newvalue)   -- send if delta value is large enough   if valdelta >= mindelta then     grp.update(sendto, newvalue)   end end
Create an event script for each object where you want to log only value changes. 1/1/1 is your "virtual" object which is logged, 2 is minimum delta between current "virtual" object value which causes new value to be sent. Adjust as needed.
checkupdate('1/1/1', 2)
As for storage, do you mean script storage? In newer releases it's stored in a separate database and there's no easy way to delete some of the entries unless you know all of their names. You can only do a full clear operation.
RE: Log only objects changes / remove storage files - gtsamis - 03.10.2016
(03.10.2016, 07:11)admin Wrote: The only solution that I see is that you create another object for each one you want to log and then filter the input value in an event script.
Thank you for the answer, unfortunately for object logging it doesn't seem optimized solution, probably i will switch to general logging where i can filter what and when to log it.
By the way, is there any way i could check objects previous state before the database update and without using storage?
For the second question I mean storage used by storage.get and storage.set
George
Well, object log main purpose is to log all telegrams. If you want to log changes you can try using trends instead. Each event script is executed only after new value has been updated in the database, so you should use storage or another object if you want to get previous value.
New firmware has storage.keys funciton which returns keys for all known storage items.
(03.10.2016, 09:14)admin Wrote: Well, object log main purpose is to log all telegrams. If you want to log changes you can try using trends instead. Each event script is executed only after new value has been updated in the database, so you should use storage or another object if you want to get previous value.
Is there any way to completely remove a storage key that not longer used?
storage.delete(key)
