Scripting - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Scripting (/showthread.php?tid=4085) |
Scripting - XSPA2474KW - 09.06.2022 Hello I have used the scripts below and I have also turned off the 2 step verification in google account function Email(to, subject, message) -- make sure these settings are correct ---------------BEGINNING OF USER EDITABLE AREA------------------- local settings = { -- "from" field, only e-mail must be specified here from = 'XXXXXX@gmail.com', -- smtp username user = 'XXXXXX@gmail.com', -- smtp password password = 'XXXXXXX', -- smtp server server = 'smtp.gmail.com', -- smtp server port port = 465, -- enable ssl, required for gmail smtp secure = 'tlsv1_2', } -------------------END OF USER EDITABLE AREA--------------------- local smtp = require('socket.smtp') local escape = function(v) return '<' .. tostring(v) .. '>' end -- message headers and body settings.source = smtp.message({ headers = { to = escape(to), subject = subject, }, body = message }) -- fixup from field settings.from = escape(settings.from) settings.rcpt = { escape(to) } return smtp.send(settings) end require('user.Email') Email("XXXXXX@gmail.com", "Alarm", "Παραβίαση Σπιτιού") Email("DDDDDD@gmail.com", "Alarm", "Παραβίαση Σπιτιού") log(mail("XXXXXX@gmail.com") ) it can't send an email and I have the error below User script 5: attempt to call global 'mail' (a nil value) stack traceback er RE: Scripting - admin - 09.06.2022 Log the results like this: Code: res1, err1 = Email("XXXXXX@gmail.com", "Alarm", "Παραβίαση Σπιτιού")
res2, err2 = Email("DDDDDD@gmail.com", "Alarm", "Παραβίαση Σπιτιού")
log(res1, err1)
log(res2, err2)RE: Scripting - XSPA2474KW - 09.06.2022 Sorry can't understand. Where should I add this code? In send email script? RE: Scripting - admin - 09.06.2022 Yes, add it to the sending script. The original error is from calling function named mail instead of Email. It is also called without subject/message body. Code: require('user.Email')
log(res1, err1)
log(res2, err2)RE: Scripting - XSPA2474KW - 09.06.2022 Hello, I have added, but nothing. I get not an error in the log screen of Wiser but also I don't receive any email. RE: Scripting - admin - 09.06.2022 What do you get in Logs tab (not Error logs)? There must be something otherwise the script didn't run at all. RE: Scripting - XSPA2474KW - 09.06.2022 Please see the picture RE: Scripting - admin - 09.06.2022 Due to recent security policy changes Gmail SMTP won't work from scripts. You need to use different email provider. RE: Scripting - XSPA2474KW - 09.06.2022 And which is the code for the different email provider? RE: Scripting - XSPA2474KW - 10.06.2022 Hello can you tell me what should I change? RE: Scripting - Daniel - 10.06.2022 Script is the same only you must setup email function with details from other email provider. RE: Scripting - Daniel - 10.06.2022 Have a look here, gmail might actually work https://forum.logicmachine.net/showthread.php?tid=4076&pid=26361#pid26361 |
