Air conditioning - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Air conditioning (/showthread.php?tid=4096) |
Air conditioning - Danny - 17.06.2022 Dear readers, I am looking for the following: I have an air conditioning control but when the desired temperature is reached the fan continues to run. now I want to switch off the air conditioning completely on the basis of the desired temperature and the current temperature and also on again with a hysteresis. Desired temperature 5/2/14 Current temperature 5/1/14 air conditioning on off 6/1/0 1 byte object and must have a 0 for off and a 3 for heating and 9 for cooling Can someone please help? RE: Air conditioning - RomansP - 17.06.2022 Hello, here is a script, you can make it resident. Code: summer = grp.getvalue('6/1/1') -- boolean if '0' is winter, if '1' is summer
winter = not summer
current = grp.getvalue('5/1/14')
setpoint = grp.getvalue('5/2/14')
running = grp.getvalue('6/1/0') ~= 0
hysteresis = 0.5
value = nil
if (running and summer) then
if current < (setpoint - hysteresis) then
value = 0 -- off
elseif (summer and current > (setpoint + hysteresis) ) then
value = 9 -- cooling
if(running and winter) then
if current > (setpoint + hysteresis) then
value = 0 -- off
elseif (winter and current < (setpoint - hysteresis) ) then
value = 3 -- heating
if value then
grp.write('6/1/0', value)
end |
