Run a LUA script via another script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Run a LUA script via another script (/showthread.php?tid=4103) |
Run a LUA script via another script - Kilogica - 21.06.2022 Hello, is it possible to run a script via another script? RE: Run a LUA script via another script - Daniel - 21.06.2022 You can enable, disable one script by another script.enable('scriptname') script.disable('scriptname') RE: Run a LUA script via another script - Kilogica - 21.06.2022 Yes, I already know that thanks. But what if I want to trigger that script by another script? I had to make a virtual object and trigger the script or it can be done via code? Many thanks! RE: Run a LUA script via another script - Daniel - 21.06.2022 Yes use virtual object. |
