Using Reactor not TP connection - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Using Reactor not TP connection (/showthread.php?tid=4118) |
Using Reactor not TP connection - Frank68 - 29.06.2022 Greetings I am using reactors to supervise only the inputs on board, not having connected the TP I always get the error message when I connect and the CPU load is always high, if I switch to IP everything works, without problems, scripts etc. etc .., even remote access with ZeroTier Thank you RE: Using Reactor not TP connection - Daniel - 29.06.2022 This is correct, you should select knx ip when tp is not used. RE: Using Reactor not TP connection - admin - 29.06.2022 High CPU load is caused by something else not by having KNX/TP disconnected. Install the Group monitor app and check if you have any duplicate telegrams. RE: Using Reactor not TP connection - Frank68 - 29.06.2022 (29.06.2022, 09:32)admin Wrote: High CPU load is caused by something else not by having KNX/TP disconnected. Install the Group monitor app and check if you have any duplicate telegrams. i don't use the tp bus, so i could set knx / ip instead of tp, would the scripts keep going? I guess yes, my only question is that I have 3 REACTORS that use the same group addresses, they are not networked with each other, but they use zerotier as a VPN not that having the same group addresses creates conflicts for me, not should they since the vpn e'punto punto? A thousand thanks RE: Using Reactor not TP connection - admin - 29.06.2022 Scripts don't rely on the KNX connection to work. Multicast (KNX/IP) is not sent to ZeroTier by default so multiple devices on the same ZeroTier network won't receive KNX/IP telegrams from others. RE: Using Reactor not TP connection - Frank68 - 29.06.2022 (29.06.2022, 12:43)admin Wrote: Scripts don't rely on the KNX connection to work. Multicast (KNX/IP) is not sent to ZeroTier by default so multiple devices on the same ZeroTier network won't receive KNX/IP telegrams from others. perfect thank's |
