last active groupadress - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: last active groupadress (/showthread.php?tid=4144) |
last active groupadress - Dré - 11.07.2022 I hope someone can help me. i want to make a script to automatic activated my alarm. so i need to know what group address was last changed. i want to check all group adresses between 14/0/25 and 14/0/68 *but there are some group adresses they dont excist. and if group adress 14/0/49 or 14/0/52 was last who changed, i want to sent a 'true' command to 14/2/1 i hope it doenst matter if some of them are still active of or not, i just want to know who was the last one who changed of state. RE: last active groupadress - admin - 11.07.2022 Use an event script with a tag and check event.dst RE: last active groupadress - Dré - 12.07.2022 Hi admin, is it also possible to run a script on scheduled en just check at that moment? to check what adres did chanced last? I only want run the script on 11pm. so i think it is better to just check that time. RE: last active groupadress - admin - 13.07.2022 Use this: Code: tagobjs = grp.tag('tag_name')
maxtime = 0
for _, tagobj in ipairs(tagobjs) do
updtime = tonumber(tagobj.updatetime) or 0
if updtime > maxtime then
obj = tagobj
maxtime = updtime
log(obj)RE: last active groupadress - Dré - 14.07.2022 Thanks admin, it looks like it is working. Just curious to understand better scripts. Why is this part of script need for? Code: if updtime > maxtime thenand why doesnt work Code: log(tagobj)RE: last active groupadress - admin - 14.07.2022 maxtime stores the maximum update time, it is changed when an object with a larger update time is found. Another option would be to sort the tagged object table by the updatetime field and use the first element of the table. tagobj is a local variable and it's only visible inside the for loop. |
