Cloud on three Logic - Printable Version
+--- Thread: Cloud on three Logic (/showthread.php?tid=4156)
Cloud on three Logic - CristianAgata - 22.07.2022
Hi at all,
I've a boubt, I have a client that need to connect three different logic under a only one account. All connections has the same cloud account.
Is it possible have a sequence of operations to do this in the best way?
Best regards Cristian
RE: Cloud on three Logic - Daniel - 22.07.2022
Just create there networks in cloud and link LM to each. In Mosaic cloud you will have selection in top right corner which LM you want to see. Make sure you add custom name for each network. It works the same for normal users when you give them permissions in LM.
You can also use Multi-Mosaic to build single visu for all 3.
RE: Cloud on three Logic - CristianAgata - 22.07.2022
(22.07.2022, 14:25)Daniel Wrote: Just create there networks in cloud and link LM to each.  In Mosaic cloud you will have selection in top right corner which LM you want to see.  Make sure you add custom name for each network. It works the same for normal users when you give them permissions in LM.
Thanks it works
Hi Daniel,
Last thing then I wish you a best weekend......
There is a way to change in mosaic the words in the top frame 'main screen' with another words (IE 'casa_vacanze').
