Schnieder Meter 64-bit register from 16-bit Register - Printable Version
+--- Thread: Schnieder Meter 64-bit register from 16-bit Register (/showthread.php?tid=4167)
Schnieder Meter 64-bit register from 16-bit Register - Ian@GWTi - 01.08.2022
I am looking to generate a 64-bit register from individual 16 bit registers from Schnieder meters,  See attached info sheet.
We are having to read the meters from a different KNX device which can only read the 16-bit registers and do the conversion in the logic machine.  This will then display the total on a visual interface.
I would also like it to send the valve back to the KNX bus.
.docx   Schnieder Electric Meter Modbus - How to Read 64bit registers.docx (Size: 13.38 KB / Downloads: 68)
Any help would be much apricated.
RE: Schnieder Meter 64-bit register from 16-bit Register - Daniel - 01.08.2022
Which meter exactly do you need?
RE: Schnieder Meter 64-bit register from 16-bit Register - Ian@GWTi - 01.08.2022
We use the PM31 and PM51 Meters,
Just looking at the modbus commands.  I think i could i use modbus address 2700 instead of breaking down the 64bit 3204 address?
See this profile.
