LM, EGX150 and PM simulator - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: LM, EGX150 and PM simulator (/showthread.php?tid=4174) |
LM, EGX150 and PM simulator - SigmaTec - 04.08.2022 Hi all, I want to know if it is possible, via a script, to use LM as a Modbus slave of an EGX150 gateway (Schneider). My project is to simulate an iEM3155 powermeter and to send power values to EGX150 so that it sends them in TCP/IP to another system. I found a script on the forum, but it is adapted to KNX objects: this is not my case, I have virtual objects in LM. Thank's in advance for your help. Have a good end of week. Dominique RE: LM, EGX150 and PM simulator - admin - 04.08.2022 There's no difference which object range is used - standard or virtual. RE: LM, EGX150 and PM simulator - SigmaTec - 04.08.2022 (04.08.2022, 12:40)SigmaTec Wrote: Hi all, Ok Admin, so I may not have the right script. Can you tell me one that will allow me to carry out my project? LM (simulate a Powermeter as iEM3155) -> EGX150 (gateway) -> Product reading Egx150 I may not have the right script. Can you tell me one that will allow me to carry out my project? LM (simulate a Powermeter) -> EGX150 (gateway) -> Product reading Egx150 All the best Dominqiue RE: LM, EGX150 and PM simulator - admin - 04.08.2022 This is the script: https://forum.logicmachine.net/showthread.php?tid=181 But it will be rather complicated because meters use 4/8 byte values which require multiple registers to store them. RE: LM, EGX150 and PM simulator - SigmaTec - 04.08.2022 (04.08.2022, 13:16)admin Wrote: This is the script: https://forum.logicmachine.net/showthread.php?tid=181 Thank's dear admin, if I understand this script correctly, it initializes registers starting from 0. If I force the registers to 3000, 3002 and so on, I get an "out of bounds"! Any idea for me? RE: LM, EGX150 and PM simulator - SigmaTec - 05.08.2022 Dear admin, maybe I misspoke, excuse me please... My need is the following : With an Lua script, I have to write register's values in an EGX150 gateway, as if LM was a Powermeter. My objets : "0/0/1" = "3000" (register name 1, float32) "0/0/2" = "3204" (register name 1, int64) and so on... "1/0/1" = 32 (register 1 value) "1/0/2" = 22000 (register 2 value) and so on... EGX150 : @IP 192.168.1.104 LM : @IP192.168.1.49, slave ID 101 Modbus TCP port : 502 Could you teach me how to do this please ? Thank's and have a good day. Dominique |
