lua table - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: lua table (/showthread.php?tid=4180) |
lua table - benanderson_475 - 08.08.2022 i have table for some lua code for porting to mqtt like the below knx_cfg = { ['3'] = {tag = 'Lounge Main', dim_ = true, knx_sw = '1/2/1', knx_sw_fb = '1/3/1', knx_dim = '1/4/1', knx_dim_fb = '1/5/1'}, ['5'] = {tag = 'Lounge Seating', dim_ = true, knx_sw = '1/2/2', knx_sw_fb = '1/3/2', knx_dim = '1/4/2', knx_dim_fb = '1/5/2'}, } if i check if for key that exists in table eg ['3'] or ['5'] all is well if knx_cfg['3'].dim_ then log( knx_cfg[3].dim_) end if i l check for a key that doesn't exist i get an error "attempt to index a nil value" which is expected as it doesn't exist all i want to know is if the check for the key element [] i am looking for which is dynamic by other code exists in the table before next process, i was trying to not have a loop through the table is there another way? Many Thanks, RE: lua table - admin - 08.08.2022 You can check like this: Code: if knx_cfg['3'] and knx_cfg['3'].dim_ then
endOr a more strict check: Code: if type(knx_cfg['3']) == 'table' and knx_cfg['3'].dim_ then
endRE: lua table - benanderson_475 - 08.08.2022 Many Thanks |
