Log / Unlog Objects via script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Log / Unlog Objects via script (/showthread.php?tid=4187) |
Log / Unlog Objects via script - Fahd - 11.08.2022 Hi, Please, is there any way to turn on the log function of some objects via a tag and scheduled script? I want to log some presence between 00:00 and 07:00, one of them is detecting a wrong motion at that time, and I don't want to log all the presences the whole day because I will get a lot of unnecessary data RE: Log / Unlog Objects via script - admin - 11.08.2022 Create two scheduled scripts that run at 0:00 and 7:00. Change group address as needed. Code: grp.create({ address = '0/0/1', log = true })Code: grp.create({ address = '0/0/1', log = false })RE: Log / Unlog Objects via script - Fahd - 11.08.2022 (11.08.2022, 06:27)admin Wrote: Create two scheduled scripts that run at 0:00 and 7:00. Change group address as needed.Thank you RE: Log / Unlog Objects via script - F.Braun - 05.05.2023 Code: y = grp.getvalue('32/1/7')
x = grp.tag('Aufzeichnung')
m = #(x)
test = x[1].address
t = '32/1/8' -- TEST
log(m,y,test,t)
if y == true then
u = 99 -- if log 99 then if was successfull
for i = 1,m,1 do
z = x[1].address --
grp.create({ address = '32/1/6', log = true })--works
grp.create({ address = z, log = true })--doesnt work
log(z,u)
u = 77 -- if log 77 then if wasnt successfull
for i = 0,m,1 do
grp.create({ address = x[i].address, log = false })
endI want to change alot of Objects that all got the same tags. -- F.Braun RE: Log / Unlog Objects via script - admin - 05.05.2023 Use an event script instead of resident: Code: enabled = event.getvalue()
objs = grp.tag('Aufzeichnung')
for _, obj in ipairs(objs) do
grp.create({
address = obj.address,
log = enabled
endRE: Log / Unlog Objects via script - F.Braun - 05.05.2023 Thank you! -- F.Braun |
