LM as Modbus slave TCP/IP - cyclic script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: LM as Modbus slave TCP/IP - cyclic script (/showthread.php?tid=4189) |
LM as Modbus slave TCP/IP - cyclic script - SigmaTec - 13.08.2022 Hi Admin, You told me that a cyclic script could only process one port number at a time, which I understand. Is there a method [as mb etslave()] to write in the registers of several slaves of the same port in this kind of script?Have a good week. RE: LM as Modbus slave TCP/IP - cyclic script - admin - 15.08.2022 At the moment you cannot have multiple slaves on the same TCP port. You need a separate script and port for each slave. |
