Linking TC900 Fan coil Thermostat with Logic machine - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Linking TC900 Fan coil Thermostat with Logic machine (/showthread.php?tid=4196) |
Linking TC900 Fan coil Thermostat with Logic machine - Shimaa - 18.08.2022 Hello everyone, Hope you're doing well. I'm trying to link a fan coil thermostat with the following part number TC907-3A4LMA with the Logic machine, and my configuration of the thermostat was : P12--Modbus Connection=On P13--Modbus Address setting=01 P14--Modbus baud rate=4800 P15--Modbus Parity Check=Odd and my configuration of Logic Machine was : RTU serial =enabled baud rate=4800 Parity Check=Odd The issue is that when mapping objects it seems that no connection as shown in the attached image. and the error log gives read failed as shown. what should I do now? Thanks for your time. RE: Linking TC900 Fan coil Thermostat with Logic machine - Daniel - 18.08.2022 Where from did you took the profile? RE: Linking TC900 Fan coil Thermostat with Logic machine - Shimaa - 18.08.2022 (18.08.2022, 12:58)Daniel Wrote: Where from did you took the profile?From Wiser for KNX (Homelynk) LSS100100 RE: Linking TC900 Fan coil Thermostat with Logic machine - Daniel - 18.08.2022 Then this profile was tested and it is correct. The problem is ether in wiring (make sure that gnd is connected) or in settings of the FCU RE: Linking TC900 Fan coil Thermostat with Logic machine - Shimaa - 18.08.2022 (18.08.2022, 15:06)Daniel Wrote: Then this profile was tested and it is correct. The problem is ether in wiring (make sure that gnd is connected) or in settings of the FCU With the same configuration of the Thermostat and the same wiring of the hardware (homelynk or logic machine), it was working well during using the SD having Homelynk firmware, but by changing the firmware to Logic machine it's not working. in both cases : Modbus Terminals of Thermostat A+ connected with D+ LM, B- of Thermostat connected to D- of LM. RE: Linking TC900 Fan coil Thermostat with Logic machine - Daniel - 18.08.2022 As you can see homelynk hardware is not the same as LogicMachne. Revert it back. |
