Fading icon image - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Fading icon image (/showthread.php?tid=4197) |
Fading icon image - Kilogica - 19.08.2022 Hello there, is there a way to make two icons slowly fade instead of simply disappear? For example: I have two leds icon each one of a color (red and blue) linked to a thermostat heat/cool function is it possible to make them slowly fade in/out when I switch mode? E.g. when I switch from cooling to heating the blue one slowly fade out and the red one slowly fade in. Thanks RE: Fading icon image - admin - 19.08.2022 One option is to use hue-rotate animation which will recolor your icon. In this case you need to use the same icon for both on/off state (red for this example). Set additional class to recolor Custom CSS: Code: .recolor {
transition: filter 3s;
.recolor.on {
filter: hue-rotate(-120deg);
}Custom JS: Code: $(function() {
$('.recolor').each(function(_, el) {
var $el = $(el), addr = $el.data('object');
if (addr) {
grp.listen(addr, function(obj) {
$el.toggleClass('on', obj.value);
});RE: Fading icon image - Kilogica - 19.08.2022 Thanks, it works very well. That's a very smart solution. |
