Problems with script editing - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Problems with script editing (/showthread.php?tid=4206) |
Problems with script editing - olegrz - 27.08.2022 Hi, I have LM5 Reactor Lite (SW: 20180828) in operation since 2019. Some days ago I met problem with script editing. When I try to edit script by pressing of corresponding icon in "Editor" column I receive empty new screen. In the same time scripts operate normally. Also FB Editor icon is disappeared from the main screen. Deinstall/Install procedure did not help me. There were no these problems one month ago. Could you advice me hove to overcome these problems? Thnx! KR Oleg RE: Problems with script editing - admin - 29.08.2022 Sounds like an micro SD card issue. Make a backup and replace the card. Follow this guide on how to flash recovery firmware: https://openrb.com/reflash-logicmachine3-and-streaming-player-software/ RE: Problems with script editing - olegrz - 29.08.2022 (29.08.2022, 06:27)admin Wrote: Sounds like an micro SD card issue. Make a backup and replace the card. Follow this guide on how to flash recovery firmware: https://openrb.com/reflash-logicmachine3-and-streaming-player-software/ Hi, OK. Thnx. I'll try, but it will be the 3rd microSD replacement on this site that too far from me now :-( May be exist additional checking to identify and resolve this problem ? Thnx a lot! RE: Problems with script editing - admin - 29.08.2022 Use a higher quality card - either industrial or high endurance. Don't use scripts that constantly write to the card (e.g. log export to local FTP). |
