massive data logging - Printable Version
+--- Thread: massive data logging (/showthread.php?tid=4217)
massive data logging - gdimaria - 05.09.2022
Hi, I need to trend log about 250/300 KNX objects.
I know that's over LM possibilities due the 21 Mb archive limit.
Can you suggest an appropriate device to do this job?
I already knows BAB TECHNOLOGIE GmbH DATALOGGER V2 (https://bab-technologie.com/datalogger-v2/?lang=en), it could be ok.
But I trust in your experience and I would receive a suggest.
Peppe
RE: massive data logging - admin - 06.09.2022
With low resolution / retention settings you could fit 300 trends into LM. An alternative solution is to use Grafana - either cloud-hosted or by installing it locally on a small PC. Installation can be a bit tricky but it's a very flexible solution for storing time-series data.
RE: massive data logging - gdimaria - 07.09.2022
Grafana seems to be very cool! And how to connect LM to it, sending telegrams via remote access?
RE: massive data logging - admin - 07.09.2022
LM is sending data to InfluxDB using HTTP. This thread has working examples: https://forum.logicmachine.net/showthread.php?tid=1531
Another option is MQTT: https://grafana.com/blog/2021/08/12/streaming-real-time-sensor-data-to-grafana-using-mqtt-and-grafana-live/
RE: massive data logging - gdimaria - 14.09.2022
(07.09.2022, 07:47)admin Wrote: LM is sending data to InfluxDB using HTTP. This thread has working examples: https://forum.logicmachine.net/showthread.php?tid=1531
Things are little changed on InfluxDB:
https://docs.influxdata.com/influxdb/cloud/organizations/buckets/create-bucket/#create-a-bucket-using-the-influxdb-api
it seems a little too complicated to me... no shorter ways to implement a massive data logging?
Peppe
RE: massive data logging - admin - 14.09.2022
You only need to create a bucket once. It will store your data for a certain amount of time. There are examples of sending data to influx v2 in the topic I've linked to.
The setup part is a bit complicated but you only have to do it once Smile
RE: massive data logging - gdimaria - 15.09.2022
(14.09.2022, 11:33)admin Wrote: You only need to create a bucket once. It will store your data for a certain amount of time. There are examples of sending data to influx v2 in the topic I've linked to.
I accepted the challenge! Smile
But right now I get error messages:
* arg: 1
  * string: error sending to influx
* arg: 2
  * string: {"code":"invalid","message":"at line 1:36: cannot parse value for field key \"value\": invalid float value syntax (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
  * number: 400
* arg: 4
  * string: rawdata,name=ora,addr=33/1/9 value=10:57
and
* arg: 1
* arg: 2
  * string: {"code":"invalid","message":"at line 1:47: cannot parse value for field key \"value\": invalid bool value \"Thu\" (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
  * number: 400
* arg: 4
  * string: rawdata,name=giornomeseanno,addr=33/1/8 value=Thu 15-09-2022
the script I used is the following, can you help me?
local socket = require('socket') local http = require('socket.http') http.TIMEOUT = 5 local dt_cache = {} function get_value(addr, datahex)   local dt = dt_cache[addr]   if(not dt) then     dt = grp.find(addr)     dt_cache[addr] = dt   end     return knxdatatype.decode(datahex, dt.datatype), dt end function knx_callback(event)   local addr = event.dst   local value, dt = get_value(addr, event.datahex)   send_metric('rawdata', dt.name, addr, value) end function send_metric(table, name, addr, value)   if name == nil or name == '' then     return   end   name = string.gsub(name, ' ', '\\ ')   local url = 'https://europe-west1-1.gcp.cloud2.influxdata.com/api/v2/write?bucket=XX&org=XXX'   local body   if type(value) == 'boolean' then     body = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value)   else     -- most likely number     body = string.format('%s,name=%s,addr=%s value=%s', table, name, addr, value)   end   local res, code = http.request({     url = url,     method = 'POST',     body = body,     headers = {       Authorization = 'Token XXXXXXXXXXXXXXXXXXX'     }   })   if code ~= 204 then     log('error sending to influx', res, code, body)   end end function run_loop()   local bus = require('localbus').new(1)   bus:sethandler('groupwrite', knx_callback)   local busfd = socket.fdmaskset(bus:getfd(), 'r')     while(true) do     res, fbus = socket.selectfds(10, busfd)     if(fbus) then       bus:step()     end   end end run_loop()
RE: massive data logging - admin - 15.09.2022
You're sending string data (10:57 and Thu 15-09-2022) which Influx does not understand. String values must be enclosed in quotes.
Try replacing lines 35..42 with this:
local body if type(value) == 'boolean' or type(value) == 'number' then   body = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value) elseif type(value) == 'string' then   body = string.format('%s,name=%s,addr=%s value=%q', table, name, addr, value) else   log('invalid data type', addr, type(value))   return end
Currently this script sends values for all objects. There should be some filtering implemented so only the required data is pushed.
(15.09.2022, 09:23)admin Wrote: You're sending string data (10:57 and Thu 15-09-2022) which Influx does not understand. String values must be enclosed in quotes.
ok, now it's collecting data.... and yes, I need to filter them.
I guess I have to modify the function knx_callback(event), but my object addresses are not in a specific range, so I need to implement a sort of list of addresses to send.
This example will push only objects that have influx tag attached.
local http = require('socket.http') http.TIMEOUT = 5 local objs = {} local tagobjs = grp.tag('influx') for _, obj in ipairs(tagobjs) do   objs[ obj.address ] = {     name = obj.name:gsub(' ', '\\ '),     datatype = obj.datatype,   } end function callback(event)   local addr = event.dst   local obj = objs[ addr ]   if obj then     local value = knxdatatype.decode(event.datahex, obj.datatype)     sendmetric('rawdata', obj.name, addr, value)   end end function sendmetric(table, name, addr, value)   local url = 'https://europe-west1-1.gcp.cloud2.influxdata.com/api/v2/write?bucket=XX&org=XXX'   local body   if type(value) == 'boolean' or type(value) == 'number' then     body = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value)   elseif type(value) == 'string' then     body = string.format('%s,name=%s,addr=%s value=%q', table, name, addr, value)   else     log('invalid data type', addr, type(value))     return   end   local res, code = http.request({     url = url,     method = 'POST',     body = body,     headers = {       Authorization = 'Token XXXXXXXXXXXXXXXXXXX'     }   })   if code ~= 204 then     log('error sending to influx', res, code, body)   end end local busclient = require('localbus').new() busclient:sethandler('groupwrite', callback) while true do   busclient:loop(1) end
RE: massive data logging - gdimaria - 16.09.2022
(15.09.2022, 12:55)admin Wrote: This example will push only objects that have influx tag attached.
Everything is fine (although I still have to learn how to handle the data to create a decent report Smile )
Now  I have the final step: to connect influxdb to Grafana.
I don't know how to choose the right authentication metod to connect it. Where to put the token and org name??!
RE: massive data logging - admin - 19.09.2022
If you switch to Flux query language then you can specify access token, org and bucket.
This might be helpful:
https://medium.com/@nanditasahu031/integration-of-influxdb2-with-grafana-28b4aebb3368
https://blog.devgenius.io/grafana-influxdb-as-sql-data-visualization-561e89b207
