Replace Micro SD Card issue - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Replace Micro SD Card issue (/showthread.php?tid=4234) |
Replace Micro SD Card issue - khalil - 12.09.2022 Hello I have an issue with the SL Micro SD Card, its become read only. I make the first step using the USB Image tool then I open the browser clear the cash >> choose the Image file>> Upload then I have this Message: Bad Gateway the process didn't produce any response RE: Replace Micro SD Card issue - admin - 12.09.2022 Try this recovery image: https://dl.openrb.com/recovery-mxs-1g.img.gz RE: Replace Micro SD Card issue - khalil - 12.09.2022 (12.09.2022, 08:54)admin Wrote: Try this recovery image: https://dl.openrb.com/recovery-mxs-1g.img.gz Thanks How much time it should take, more than 10min elapsed but still not finished! RE: Replace Micro SD Card issue - admin - 12.09.2022 It should take no more than 5 minutes to finish. Can you ping the device? RE: Replace Micro SD Card issue - khalil - 12.09.2022 (12.09.2022, 08:54)admin Wrote: Try this recovery image: https://dl.openrb.com/recovery-mxs-1g.img.gz Hello Admin This recovery image should I use it to create the MicroSD Card with the USB Image tool? RE: Replace Micro SD Card issue - admin - 12.09.2022 Yes, the same way as with the older recovery. But you should see the same window as for standard firmware upgrade. RE: Replace Micro SD Card issue - khalil - 12.09.2022 (12.09.2022, 10:24)admin Wrote: Yes, the same way as with the older recovery. But you should see the same window as for standard firmware upgrade. Thanks Admin Its worked now But what could make the original recovery file not working? RE: Replace Micro SD Card issue - admin - 12.09.2022 It's an older recovery image with 16MB upload file limit. Newer firmwares are larger so you get an error. Updated recovery image can handle firmwares up to 32MB. |
