lots of curve with highlight - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: lots of curve with highlight (/showthread.php?tid=4236) |
lots of curve with highlight - domotiqa - 12.09.2022 Hi, Is there a way to scroll the the list to the good curve the mouse pointer is above. I explain. When using lots of curve like here: Sometimes we need to go over a point but the name curve is at the bottom of the list, so hard to find the right value. Is there a css trick or JS ? Regards RE: lots of curve with highlight - admin - 13.09.2022 This will be fixed in the next release. In the meantime you can use this custom JS: Code: $(function(){
if (window.Chart) {
Chart.$c.on('mousemove', function() {
var el = document.querySelector('.flotr-legend-hl');
if (el) {
el.scrollIntoView();
});RE: lots of curve with highlight - domotiqa - 13.09.2022 thks a lot ! |
