Supervising 50 Alarm modbus registers - Printable Version
+--- Thread: Supervising 50 Alarm modbus registers (/showthread.php?tid=4240)
Supervising 50 Alarm modbus registers - Fahd - 14.09.2022
I have about 50 Modbus coils for alarms and I have to supervise all of them.
So, Is there any way to make a scrollable area and display only the object that has an alarm?
It will be empty if there's no alarm and it will show the alarms below each other if there's more than one.
something like in the attachment
Grateful in advance
RE: Supervising 50 Alarm modbus registers - Daniel - 14.09.2022
Have you seen alert app? It might fit to your use case.
RE: Supervising 50 Alarm modbus registers - Fahd - 14.09.2022
(14.09.2022, 10:03)Daniel Wrote: Have you seen alert app? It might fit to your use case.
I didn't use it yet, can I display the app on the same SCADA page?
sure via frame
RE: Supervising 50 Alarm modbus registers - admin - 14.09.2022
This can be helpful as well: https://forum.logicmachine.net/showthread.php?tid=350
