Push Notifications iOS - Printable Version
+--- Thread: Push Notifications iOS (/showthread.php?tid=4279)
Push Notifications iOS - tpospichal - 02.10.2022
Hello I am not able to register iOS devices to the push notification app. Android works OK.
Everything is updated
I Instal/uninstall LM app on devices create new users/Disable mobile networks to be sure, that iOS cominucate locally, try Basicaly everything, but no success.
Is there any other settings which needs to be checked on the iOS for successful registration to the Push notification app?
Thank you
RE: Push Notifications iOS - Daniel - 03.10.2022
Which version of iOS?
RE: Push Notifications iOS - tpospichal - 12.10.2022
(03.10.2022, 07:38)Daniel Wrote: Which version of iOS?
Sorry for the delay: 16.0.2 (20A380)
RE: Push Notifications iOS - Daniel - 12.10.2022
I just tried it on iOS16.3 and it worked correctly. Which fw and version of push app you use?
You must be on the local network with LM to make it to work.
RE: Push Notifications iOS - tpospichal - 21.10.2022
(12.10.2022, 10:34)Daniel Wrote: I just tried it on iOS16.3 and it worked correctly. Which fw and version of push app you use?
FW is: 20211215
App version:20211216
Everything is updated, local network.... On my android device everything works, but client iphone no succes after many many tries. Is possible to get some error logs or any suggestions what to do?
Thank you
RE: Push Notifications iOS - Daniel - 21.10.2022
Did you try to uninstall the app from the mobile and install again?
(21.10.2022, 07:34)Daniel Wrote: Did you try to uninstall the app from the mobile and install again?
Yes many times
